motor starts and idles fine, runs rough when put into gear the stall when power is applied, any ideas
2004 70TLRC Yamaha
Part #21 is the main jet(s) which as posted above, is likely clogged up;
2004 70TLRC Yamaha Outboard CARBURETOR Diagram and Parts
If its idleing, that idle jet is most likely clear but pull both, physically LOOK thru all jets, don't just blow carb cleaner in the housing.
When you drain the carbs, (drain plug on the lower float bowls), try and catch what comes out checking for crap, water, etc.
Old, untreated fuel is NOT your friend. In addition to a fuel stabilizer, run Yamaha's "RingFree". Its a fuel system/top end cleaner that works extremly well. If used regularly, with a stabilizer, you won't have any more carb issues..Scott
