Originally posted by rejesterd
View Post
F115 Electrical Troubleshooting Help
Originally posted by 99yam40 View Postis that peak volts measured with the proper voltmeter or with a DVA and regular meter.
I also would expect to see voltage at the battery above 13 even at idle
I believe I have solved my problem. Last month I discovered my batteries were no longer charging. Voltage rectifier/regulator was fried along with a few pins at its connector. I replaced the rectifier and connector...it fixed my charging problem but not the overall misfire. However I kept at the electrical troubleshooting and decided to swap in a borrowed ECU. The motor ran great on the borrowed ECU for 15 to 20 minutes with no sign of misfire at any rpm. Today I ran it again just to be sure. Ran great on the borrowed ECU, then swapped in my old ECU and the misfire came back after 2.5 minutes...I assume because it heats up to a temperature where it starts to fail. As to the overall cause of the bad ECU, I suppose it may have been related to the fried rectifier/regulator and perhaps some battery wiring that I cleaned up over a year ago. As an aside, I've read about stuck ISC valves causing ECU's to go bad, but I think my ISC is fine as I can hear it clatter every time the motor shuts down and rpm's at startup and idle behave appropriately. Anyhow, nice to have closure on this one.
ÂÂÂÂÂÂÂÂÂ
