I just wanted to thank you guys for your advice. Between waiting for the replacement head gaskets etc. and ordering an O.E.M. water pump, I finally got the pump today. Installed it and no more overheating. This has been causing me grief for over a month, a few days ago I fit the original housing on the pick up tube then transferred the rubber seal to the aftermarket housing and slid it on the pick up tube. There was quite a bit more slop with the aftermarket one so I'm guessing that this was the problem all along. Guess I learned the hard way, I bought aftermarket because I could them quickly but that will be the last time that I do that.
Thanks again guys.
Btw, I do have a question about the timing pick up setting. Could I ask it here or should I start a new post?
Thanks again guys.
