I am having a fuel issue that I am not sure how address. The fuel lines are clear all the way through the fuel filter and to the pump, but I have fuel squirting out of the back side of the fuel pump every time I squeeze the bulb. The harder I squeeze the bulb the farther the gas squirts out, this is not just a drip or two. I was told that this indicates a carburetor float issue that will not allow gas into the carb. Is this correct or is this a cracked or broken fuel pump?
I can get the motor to start briefly by squirting gas into the carburetor with a quick shot of starting fluid. After turning the engine over the fuel bulb is soft so I am not sure if that is correct.
Any information or advice that you can provide will be greatly appreciated. Do I need the carburetors cleaned and rebuilt or is this directly related to the fuel pump?
Thanks in advance,
Thanks in advance,
