Is it now missing at idle at all engine temperatures - from cold until it gets hot?
Does it ever sneeze whenever it is idling?
Is it missing with the choke plate closed or with the choke plate open?
Have you checked the idle mixture setting screw?
If the plugs were clean and tan after the motor was being run at power, with no problems, but then the plugs get black and wet after the motor idles for a period of time, and the miss starts, I would focus on the idle mixture setting.
At what altitude are you?
