Can someone here in this forum please post a photo of exactly where the water pressure TUBE fitting is located on a 2013 F150XA 4 cylinder 4 stroke?
Backstory. My daughter purchased a Mako 19' with this engine. The boat has an analog tubing-type water pressure gauge. The tubing goes back to the engine but it not terminated. I verified it with some air pressure while watching the gauge. I have studied these fora for answers, but have not been to find an answer to this particular question.
All I need to do is connect the tube to a fitting on the engine. I understand the fitting is a standard M14 thread. That's fine. But excactly WHERE on the engine do I screw in the fitting?
Rather than describing it, please post an actual photo of your tube fitting location. Thanks in advance.
Note: this is NOT an electronic sensor. Instead, this is the old-fashioned hollow tube that carries pressure to the gauge.
