Hello Everyone,
I have a 2003 115 four stroke and out of the blue the first time I start the motor it will idle for one minute then shut off. restart and same results for a number of times. Then something happens and it will run fine the remainder of the day. Sometimes when at first start i will put into gear and it may or may not stay running. If it does i slowly get out to open water then throttle up and then it shuts off again.
I just received the software and cable and hooked up no recent codes. I did find the shift senor position switch sticking.
I just replaced fuel line to motor and primmer ball. This summer replaced VST filter and installed new injectors. Also put in a new fuel filter twice in the last two outings.
Any ideas would be appreciated.
Thanks,
Dean
Thanks,
Dean
