Ferris thanks for searching and finding that.
My memory is not totally gone yet ,but I could not remember what the possible cause was.
too bad the OP on that thread never came back and reported what the fix turned out to be.
seems that the wrong trim tab could be the problem
or the tube is plugged with sand/mud/shell
or lower unit is not meant to run shallow( that high out of water without a low water pick up)
Thinking about that a little more, maybe Rod was saying that motors with low water pick ups allow them to run too shallow so not enough water is flowing across the prop causing it to over heat, so they designed the trim tab to scoop up water to run across the prop thru that tube
let us know what you find out.
it will help others
it will help others
