I know this issue has been posted many times, but have not found any fixes, i have twin injected 01 Yamaha, the port engine is worse than the starboard. when throttling up stumbles and shakes like you could not believe, transferring from the 4 to 6 cylinder change, everything has been changed, linked& sync, injectors, cleaned, vst filter changed , 02sensor changed tps changed . it is not as bad if the motors are trimmed up. but still has an issue. some times i have to pull the throttle back and hammer it to get it to run on 6 cyl. runs fine at idle and when it is running on all 6. my brother has the same engine and his transfers with out an issue, he runs 93 octane me mid grade. I imagine that it is the computer that controls this , could it be a wiring issue (ground) ????
or a computer issue, it has become a true pia, and i want to get it fixed . thanks
