Hi all -
This is my first post so please bear with me.
Per reading this forum I have learned that if I want a Yamaha hour meter that reads actual engine hours that the engine is running only versus key-on hours (which will be more hours and falsely and prematurely indicate when I need to go in for 50, 100, 150... etc... hour service) and that matches the Pro series (not Pro II) multifunction gauges on my boat now I need to buy the 6Y5-83504-11-00 gauge (Do I have this right?! I do not want the meter to read key on hours). I have purchased this meter and the instructions are not that good. The meter I purchased has a black, yellow and green lead but no blue lead and if I am understanding what others have said on this forum correctly these leads attach to the same color leads on the back of my existing gauges. Is this correct? If so do I need a secondary 3wire "splitter" harness to tap into my existing gauge wires? If so does anyone know what the part number for this is? Thank you in advance for your help!
