I may be an idiot . I may not have have reconnected the sensor wire this morning when I was rotating the cam . I'll bring a buddy by to be my right shoulder tomorrow and try this again !
Trim cam sensor adjustment
Originally posted by 99yam40 View PostI would not think the top bar should not be flashing.
might be that the wiring to the gauge is not making good contact in the connectors.
as someone said already, unplug the sender and short the wires to the gauge,
if still no gauge movement try shorting them at the gauge itself to see if that moves it
bad connector, wire, or gauge.
test and see
I would think the flashing would be because it is not connected
ÂÂ
