Hello everyone. So recently father and I purchased a 26 Mako with a yammy V76 250 hanging off the back of it. On its first trip it wouldn't pass 4000rpm so that week I replaced the fuel from tank to motor including primer bulb, 2nd trip still same, replaced plugs and did a power tune through the carbs and tightened all the carb linkage which was loose also checked compression and all cylinders are at 120, 3rd trip now I'm at 4600rpm at WOT. Also primer bulb won't hold prime for more than 2 to 3 min but it does get solid when primed. Motor starts and idles great and I can run 4600rpm all day with no hiccups. Any ideas on what can be holding me back from 5500 rpm????
Need help with 1994 yammy v76 250
Prop size and pitch
what holes it is set in( how high the motor is set )
Look here and see what a rig like yours should run and with what prop they used
Performance Bulletins | Yamaha Outboards
Seeing as it was originally rigged with twins, my guess is they kept one motor (after the other one had problems?) and had to cut the transom, because the shaft would have been too long, and they kept the old prop, and coming from a twin setup, it is just too big, you will have to test a much smaller one.
