I'm a relatively novice boat owner in SE Alaska and appreciate any help that the forum can provide. I have a 22' Hewescraft Searunner with a 2006 Yamaha F115 outboard at ~1000 hrs. The motor runs rough above about 4300 rpm. It accelerates and cruises just fine up to this rpm, but attempting to accelerate beyond this rpm results in the engine sounding like it's hesitating or misfiring and fluctuating between about 4400 and 4800 rpm. Before this issue cropped up the motor would run fine up to and exceeding 5000 rpm.
Over the past few months I've replaced the following items in an attempt to troubleshoot:
Next up I plan to test the fuel pressure at the fuel rail and possibly run the motor on a spare fuel tank to see if that changes anything. May also disconnect spark plugs and fuel injectors one at a time to see it I can isolate a cylinder-specific issue. Thanks for any suggestions!
- Racor fuel filter
- Primary engine fuel filter
- Inline fuel filter between low pressure pump and VST
- VST screen
- Fuel injectors (cleaned and tested)
- Pressure Regulator Valve on fuel rail
- High pressure fuel lines
- Spark plugs
