Hi, first I want to thank the forum users as I have got more knowledge than before from reading here for a couple of years.
Now feel the need to post a question about my F115 with 500 hours on it and it has been running rough on idle for the 2 years I had it but always ran OK when in gear. But now something else happened and it didnt run properly when in gear and I could not get full power. almost like it ran on 3 cylinders.
YDS says that water temp sensor is bad. error code 15. I have a new sensor on the way. My question is if the sensor has anything to do with the isc valve opening?
I get a strange number on ISC valve opening from YDS. I get 50%opening at idle 750 rpm and 53 % at 1600 rpm and 59% at 2870 rpm. Seem very low compared to what others have reporting here in the forum. For example Rodbolt said that ISC should go to 100% when >1300 rpm. I can here the ISC rattle when turning the engine of.
My tps voltage is 0.728 at idle. My other YDS numbers such as intake pressure etc is in the same range as others in the forum and seem normal.
I have cleaned the injectors and VST. exchanged the LP pump and I also here the High pres pump spin when key on.
Changed the ign coils and plugs. I got a lot of parts from a used F115.
Also when I unplug the Isc there is no real differens in idle. Did the active test with YDS and increased RPM when Increased ISC valve opening. Can I rule the ISC out ?
When I pull the vacuum hose from regulator and pinch it I do NOT get an increase in RPM nor is there any gas leaking out of it. If i just pull the hose the engnge dies.
My nr 1 plug is sooted and wet from I think gasoline. it smells so. Probably nr 1 is misfiring?
Also been running on seperate fuel tank and exhanged the inline filter. I pump the bulb but it does nothing for the rough running.
Next I think I will swap the ECU for my spare one and also try to do compression test and leak down but I need to buy the gauge first.
Anyone have any suggestions? This is driving me mad. I was thinking T-stat but it should not matter when engine is cold? it misfires from start and the idle is not fixed. it is varying about 30 rpms up and down.
What symptoms can water temp sensor cause? Someone wrote about it messing up all kind of things on his F115 but I cant really understand what it does, or how the ECU uses it. besides alarming if to hot.
