I have a 2005 f115. 804 hours. in march? it developed a miss at the end of the day. Water in cylinder. Head gasket leaking/blown. new head gasket. motor back together and it seemed fine. Initial sea trial 5.6k rpm wot and 30kts which is slightly better than it did before head gasket. Ran it to one of the local Islands and noticed what seemed like an intermittent miss in harbor at end of day at 1.4k rpms. #1 Plug fouled and smelled rich. On hose it seemed to run fine. switched injectors because I/we suspected a problem with injector. the same issue (intermittent miss/rough at 1.4k rpm) but performance fine at high rpm (wot 5.6k rpm and 30knts). Same plug fouled and running rich (could easily smell on boat when running). Put on hose today and it doesn't appear to miss at 1.4k but it surges noticeably beginning at approx 1.4k and continues to do so up to 2.2k rpm. (didn't run higher than that on hose).
While I am fairly mechanically inclined, I don't claim to be a knowledgeable or good mechanic. I can follow procedures. I was hoping that someone here could point me in the right direction.
I have yds but don't really know what to look for. Still figuring out how to use the basics of the program.
