I really did not understand what you wrote, but if you put 24volts to the F70 motor, there could be damage to all sorts of things
Command Link gateway to display Yamaha engine data on MFD stopped working
ok, I finally got around to test and good news i have 60 ohm by connecting my multi-meter to the blue wire and white wire of the CL multi-hub with key switch for power to CL multi-hub to off position and with NEMA2k backbone connected to my Raymarine Axiom also power off. So my NEMA2000 and CL are properly connected. Yes the 6YG-8A2D0-00 is also connected when doing my ohm test.
so, the only problem is the 6YG-8A2D0-00 i am going to ship it back to headquarter for a repair or replacement.
thanks a million for your help. I will post a video soon.
Originally posted by fairdeal View PostYamaha 'Command Link' is essentially NMEA 2000
so four conductors:
red=12V+,
black=ground,
and the blue and the white are the data wires.
The wiring for NMEA 2000/Command Link,
when properly configured,
is arranged in a "backbone" - with,
at each end, the white and the blue wires connected via a 120 ohm resistor
like so:
as far as testing 'data wires'
with all the devices 'off',
you should have:
- continuity between all whites,
- continuity between all blues,
- a 60 ohm resistance between white and blue, anywhere
By the way -
I didn't see what Yamaha model you are working with;
but, although Yamaha 'assumes' you will use their Gateway -
if the engine is 'mechanical control' -
NOT "DEC" / 'drive by wire' -
then you really don't need the Yamaha Gateway -
just connect up without it.Captain steve - 1974 wellcraft airslot 165 with 2019 Yamaha 70
Oh Oh, I am not 100% certain that I disconnected 1 of my 24 volts battery to get 12 volts to start my engine.
I think I did but unsure.
How do I check whether I ruined the ECM on the F70?
Please help and thanks.,
QUOTE=99yam40;n220925]I really did not understand what you wrote, but if you put 24volts to the F70 motor, there could be damage to all sorts of things[/QUOTE]
my 2019 Yamaha 70 hp is working properly, so will have to ask dealership to check th 6YG-8A2D0-00-00 gateway.
QUOTE=panasonic;n220936]The ECU is on the test machine now....the Engine. If the the engine is running properly , then the ECU is working fine.[/QUOTE]
Unbelievable. My dealer told me MY outbound ECU was sending engine data to motor #3, so they reset it to #1 and it worked. Gauge starts to display engine data.
i am fighting with Yamaha Warranty for the 2 hours labor ($270) my dealer charge me.
I have a small 17 feet boat with only ONE outboard, never had 3 motors on my tiny boat so the ECU is at fault here!
unbelievable!!!Captain steve - 1974 wellcraft airslot 165 with 2019 Yamaha 70
ÂÂÂÂÂÂ
