Hi All, My BWSeacat has twin 2008 60hp 4stroke Yamaha outboards that are fantastic and have been for 6 years and covering about 11000 nautical miles on 1400 hours motoring. So no complaints but I have an intermittent problem on one engine that is baffling the local dealer. SYMPTOMS - I get a very Intermittent overheat. I have an oven probe and display so I know the engine is getting hot when i get the alarm, I also see it cooling down after I SWITCH OFF AND ON AGAIN. THE ENGINE COOLS DOWN AND RUNS FINE. This may happen twice in a row but then is fine. Twice it has alarmed at tickover after a short run from moorings to pickup point and then fixed itself. Sometimes it will occur as I slow down to idle after a 40 minute 4800rpm run. We have changed the sensor, thermostats, water pump kit and had the head inspected which was reported to be like new. After lots of reading and three liftouts I reckon its my Pressure Control Valve. Is this likely to be the case? And if so whee is this device on my engine? I will then take any info to my trusted dealer to discuss further and hopefully resolve.
pressure control valve
How long does it take to cool down?Originally posted by ltjones2004 View PostI also see it cooling down after I SWITCH OFF AND ON AGAIN. THE ENGINE COOLS DOWN AND RUNS FINE.
Maybe you have something moving around inside blocking passages from time to time.
Have you ran in shallow water picking up sand or shell?
Have you had a water pump lose any vanes from impeller in the past?
could the internal anodes have come apart
Which of these 60s is yours http://www.boats.net/parts/search/Ya...ter/parts.htmlLast edited by 99yam40; 09-14-2014, 08:13 AM.
I am with arny.
I recently did one for a close friend that all 4 of the internal head anodes broke off and the internal anode in the cover broke off and plugged the water outlet like a bath tub stopper.
look at the parts diagram, I don't think that model used a pressure control valve.
