sounds like a good plan
2006 Yamaha 90AETO idle problems
Winter is coming so yeasterday i started the engine to spray some extra oil to engine through throttle bodies and drain the carbs after that. Also drained the gear oils.
What a huge difference now with the engine, after the carb / primestart clean. Prime Start also worked longer then never before, about 1-2 minutes because it was quite cold weather ( about 2 celsius ) and idles perfectly. Like a new engine now.
ÂÂ
