F115txra - will not restart warm
  • F115txra - will not restart warm
    Hi guys, my neighbor has a 2002 f 115txra, , it will not start after running to regular temp, it will crank,but not start, let it sit for 15 minutes ( cover off to speed cooling ) starts , runs fine. Also, new tach installed recently, and now works sporadically ( may be red herring) , new voltage regulator ,and various fuel system components have been replaced according to neighbor, any help would be appreciated, if further detail is needed I will ask neighbor for specifics , I am leaning towards vst issue , thanks again Eric
    Any ideas?
      when you turn the motor OFF, do you hear a rattling sound?
      when you turn the key ON do you hear the fuel pump whine about 3 seconds?
        I have that same motor and Yes I think I hear a rattling sound when I turn mine off...what is that?
        2002 19ft. Baystealth 1888 with Yamaha F115 (4 stroke)
        2002 15ft Alumacraft with 25 Yamaha 4 stroke
          that rattle is the ISC valve resetting to 100% in anticipation of the next start cycle.
          its part of why EFI motors start at a faster RPM than idle.
            Ever heard an F250TXR start? Ever thought about the RPM it turns long before oil has a chance to get to the motor. Makes me wince.
            My Ford truck does the same. I hate it.
              the F350 is even worse on the flusher.
              we can use it to scare the jeebers out of newbies though.
              the worst is when you have replaced a powerhead or cyl head and the cam oil control takes a bit to pressurize.
                rodbolt,
                What is the tapping like noise when starting the f50/f60/f70?
                almost sounds gulping down a beer
                  dunno.
                  typically a tapping on that motor is air in the mechanical pump.
                  typically it sounds like a collapsed lifter on an old chevy.
