Yamaha T8 had run good all day. Shut of raised the motor and saw fish on the finder so dropped it back down and started it. Idles fine but if you give it gas it would cough and backfire. Could mess with it and get it to go full throttle but only for a short time
Pulled plugs they were black.
Main motor is plumed of the same fuel filter. It runs fine.
Replaced plugs no change.
Removed plug wire one at a time at idle both have spark as motor changes struggles if one is removed.
Read multiple threads somewhat similar pointed to carb issues.
Removed carb cleaned high speed jet could not get low speed out as it stripped.
Now would not idle still could still not accelerate
As I messed up low speed jet I bought a reman carb for time issues vs getting low speed jet.
Installed new carb runs the same.
Pulling choke out does not make it better but worse.
pumping bulb does not help.
Seems to be something electrical on throttle advance?
Any Ideas?
Going to end up in the shop if I cant figure it out.
It is on the boat in the water and we have a few weeks here for coho salmon a year so any help to diagnosis would be appreciated.
Don't know if a shop manual would help on this.
If any one knows how to check the electrical on this I'd appreciate the help
thanks, SKPcoastal
Any Ideas?
thanks, SKPcoastal
