This part is not coming off and a new one didnt come with the water pump repair kit. Any suggestions on how to remove it? I have already removed the plastic housing and the ss wearplate cup.
How do I remove this part on impeller/water pump
It's a press-on plastic and stainless steel collar with some spring washers inside it....you'll need some new ones since it's almost certain to screw them up getting them off....you can sorta pry them off with screwdrivers, etc. When you install the new ones you pull up on the driveshaft while tapping the collars and spring washers down to take up slack in the driveshaft to prevent a certain knocking sound at lower RPM's....which is more of an irritation than a big mechanical problem....good luck!
As noted above that SS collor has to come off first.
If you take a fairly wide tipped, flat screwdriver, use an appropriate socket as a fulcrum to lean against, you can slowly put pressure upwards underneath that collor. Rotate it often and go slow. That's the hardest part, the rest will slip off.
Just pay attention to the order....Scott
I just did that same thing!! Yes pry on it while you rotate it, but I sprayed some WD-40 on it and it really helped! The replacement cost is not much if you break anything. That steel collar is just pressed down over the plastic piece and there are three washers below all of it. The wave washer goes in the middle I think.
I believe it is part number 20-23 this is for my 2002 F115
http://www.boats.net/parts/search/Ya...%29/parts.htmlLast edited by Pas Bon F115; 09-08-2014, 08:56 PM.2002 19ft. Baystealth 1888 with Yamaha F115 (4 stroke)
2002 15ft Alumacraft with 25 Yamaha 4 stroke
Originally posted by greasyshaft View PostIf it's real stubborn you just use fire to melt it.
myself? at 90/hr I don't play with them much.
occasionally I use a small sharp chisel and a 32OZ ball peen and two whacks and the collar is cut.
typically I wont scar the plastic.
kinda like why I don't rebuild the 6E5 fuel pumps.
at 90/hour plus the parts you would have a new rebuilt pump.
but its easier to pry on it if the cup is reinstalled.
Originally posted by skiffer2010 View PostThanks for all the replys guys. All the you tube videos dont show this step or parts. Mine was stubborn, yes used the screwdriver pry/rotate trick and wouldnt come all the way up. I had to cut it off with a cutting wheel.
Here is a link to a step by step tutorial that depicts a water pump replacement on an F200. Many of the steps are common to a number of Yamaha models.
Water Pump Replacement
Originally posted by boscoe99 View PostDid you put a spacer under the shank of the screw driver once the collar was part way off the plastic band?
Originally posted by boscoe99 View PostDo you suggest an acetylene cutting torch?
Originally posted by greasyshaft View PostYes, simply cut the drive shaft and then braze it back together. Should be strong.
nothing wrong with good homemade stuff
like I posted, I can cut that metal collar in 2-4 whacks with a good chisel faster than you can cut it with a wheel.
ÂÂÂÂÂÂÂÂÂÂÂÂÂÂ
