I Wonder if anybody can assist with the above ( part no. 6G8-835282-00). This light assembly is supposed to light all the time when the engine is running indicating that the oil pressure is OK. I'm not sure if the bulb has just blown or there is a problem with the oil pressure. The engine is cooling ok and the oil/filter has just been changed.
A new oil pilot light assembly is about £50 - which seeems an lot of money for what basically is a bulb. Is there any way I can replace just the light or check the oil pressure is ok ? Any advice would be most appreciated.
Thanks Grahame
Thanks Grahame
