Motor is a 2006 Yamaha V150TLR. Motor starts up and runs great, idle is 700rpm and *****ingspeed 550-600. After some time running, idle drops and some time stalls. This only happens after som time running. If I turn the idle up a bit it will run, but then next startup on cold motor the idle is to high.
Had an issue with water in fuel last year, got that sorted.
Done so far:
Compression is good on all 6
New fuel pumps
New spark plugs
Rebuild carbs, removed, inspected and cleaned all jets. New gaskets
Fuel filter and water seperator
Tank is clean, fresh fuel
Synk/link as in manual
Idle mix screws are set, port 1 1/16 Starboard 1 9/16
New check valves
Cooling is ok, have water pressure gauge
Motor do not smoke, running nice and sounds good. Only issue is idle when motor is warm after som time on the water.
Suggestions for other things to look for?
Done so far:
New fuel pumps
New spark plugs
New check valves
