I am having 2 issues with my F250 4 stroke outboard.
- It runs fine for a while, maybe and hour or so, then I start having lack of power, in on instance I could barely get the boat up on plane, then when I eventually did it seemed to run ok. In another instance after running at nearly full throttle it started cutting out intermittently. This happened as I was coming into the no-wake zone so I had to slow down anyway and it ran fine at low speed. Do you think this could be bad gas or is it something else? I did not get the boat in the water all year, so I have 100 gallons of 2-year-old but treated gas. I replaced the 2 first fuel filters when I winterized it 2 years ago. Have not replaced the 2 inner filters in a couple of years. Is there any harm in running out the old gas? Assuming that is the problem?
- Second issue is that most of the elements on my tachometer are not working. Could this be an electrical connection problem? Or does the unit need to be replaced? Does this interact with the engine and could it be affecting above problem?
