Hello all,
I recently completed a link & sync on my 1994 3 cylinder 2 stroke 70hp TLRS after a complete powerhead rebuild and noticed the carburettor butterfly valves aren't rotating to the horizontal (fully open position) when the throttle lever (on the control box) is in the WOT position. I'm not sure if this is normal and I can't run the motor to test it just yet.
Movement of the throttle cam seems to be limited by the timing stops on the CDI unit however the throttle lever on the carburettors requires significantly more rotation to open the butterfly valves fully after the cam control lever hits the the fully advanced stop. Hence the butterfly valves are a long way off horizontal at WOT, which seems odd.
I'd appreciate any comments on this before the initial start up.
