Don't bust a gut laughing, it's the first time this has happened!
Wife wanted to go fishing, which is odd, usually fish alone.
Anyways Have a camp close to the ramp, I back boat in water till it
floats a little, unhook winch an back off, wife parks truck.
She gets in an I hammer down an all kind of noise comes from the lower
unit, take it out of gear, idles fine, put it in forward an sounds like gears about to
fly out again. Try it a third time, everything is fine
Make a small circle getting boat on plane, sounds great, no noise
no vibrating, sounds an acts like it always has.
Tell the wife her joy ride is over, because that wasn't right.
When I was putting boat on trailer, I thought to myself,
You didn't take the transom saver off, it was still bungee corded
around lower unit, other side just rest on roller on trailer.
It's a 2003 pro v150
Prop shaft runs out around .060 by eye
I didn't an haven't ran it any, no I'll need a new shaft,
Can y'all give me a ball park figure if I put it in shop about what it will be.
Assuming the shaft is all that needs replaced. An water pump since it will be apart.
Never had any problems out of this motor, other than fuel pumps,
It's been a great motor
Thanks for any a all advice
Rob
Rob
