Just had the 200 hour service on a pair of 2007 F250's by the local Yamaha dealer. They were running fine prior to being serviced but immediately afterwards the low pressure pump failed on the stbd engine and now it has been replaced the motor surges above 4000rpm, by up to 800rpm Below 4000rpm it runs ok.
At first I thought it may be the prop cavitating or the rubber bush starting to fail, however the motor has a new Yamaha prop which was replaced along with the lower unit just 4 months ago (when someone stole the lower unit) and the dealer tells me he has never known a prop to fail so soon. There have been no external issues such as ropes around the prop.
The dealer thinks it could be an injector fault and is coming back to look at it next week as there have been issues with water in fuel, and 3 months ago I had to replace the low pressure pump on the other engine. At the previous service (100 hour service 8 months ago) a different tech fitted diesel racors. With diesel being more viscous than gas I expect the racor filters were coarser permitting more water to get past them.
If anyone has any suggestions I will be very grateful to hear from you.
Richard
Richard
