We have twin 2005 F250s, and I noticed some oil sheen behind the boat today and started searching. Turns out there is a hole in the top of the tilt trim reservoir, so we were likely running the last couple days with water getting into the Tilt Trim System. I want to get the saltwater out as quickly as possible.
Been reading up and see that there is not a drain or an easy way to just flush through new fluid and the recommend is to take it apart and manually remove all the contaminated fluid? If that’s the case, how far do I need to tear it down? Take all three rams apart, motor off? Anything else I need to be aware of?
These are are nice low hour motors, so would like to do it right.
Is there another way to flush it? Appreciate the advice.
