Have a 2011 115hp with 150 hours that just stopped peeing water when I start the engine. Had the impeller changed about 1 month ago when the problem first started, and it worked ok the next couple of times I used the boat.
Today it would not pee at all. When I hook a hose up to the fresh water flush out, it pees fine, and water comes out of all the openings in the lower unit. I took off the engine cover, and disconnected the hose on the bottom of the manifold that says "water" on one side and "fuel" on the other. Started the engine and nothing. Disconnected the upper hose and blew through it and could feel air coming out the pee hole.
Any suggestions?
Any suggestions?
