I have a new 6 hp Yamaha that was dealer prepared, ran fine 3 times for a total of 2 hours. Trying to start it now and starter cord will not pull out. Engine has oil in crankcase. Is in neutral. I do not know what is really wrong but it acts like starter pawl return spring may be broken. I really need it to run tomorrow. Thank you for your suggestions.
Manual starter cord will not pull, F6ELH
And turn it in the normal running direction..
Are there any "safety's" on the cover or ? that may be locking up the pull starter?
Your motor isn't listed in the US parts fisch, I suspect your outside the US.
Anyway, the closest engine starter assembly is;
http://www.boats.net/parts/search/Ya...ER/parts.html#
Parts #20, a cable, appears to be a safety. You may try shifting back and forth should that cable not be adjusted (IF there is an adjustment) correctly.. The engine may think its in gear and NOT allow you to pull start it.Last edited by TownsendsFJR1300; 08-16-2014, 11:31 AM.Scott
