Hi I have 2003 25HP Yamaha 2 stroke manual start. Model 25MSHB How can I make the engine charge my battery? I would also like to run a tachometer to prop the engine right.. Thanks.
2003 Yamaha 2 stroke 25hp charging capabilities and tachometer question
a rectifier changes AC power to DC.
the rectifer/regulator changes AC to Dc and keeps the voltage in control to keep from over charging the battery by bleeding off the excess.
but then I do not think that 25 puts out very much power( maybe 6 amps) probably need to look that up to be sure
There are many ways to skin this cat. I would go with a non-Yamaha R/R and leave it outside of the cowling. Maybe at the battery. Yamaha makes a cable to do this with. Part number 682-84380-00-00.
https://www.boats.net/product/yamaha/682-84380-00-00?q_ref=682-84380-00-00
Of course you could just string your own wires and save some money.
I would then get a cheap aftermarket R/R and connect it to the leads that come from the motor at one end and to the battery posts at the other end. For instance.
https://www.dbelectrical.com/product...-esp10150.html
Â
