I'm having a problem maintaining rpms between 2000 and 3000 as soon as I can get it above 3200 it seems to be holding. Have had other issues with rpms but nothing like this. Any help would be appreciated.
Rpm's dropping
at that RPM some hulls simply are plowing and lugging the engines.
it could be either engine has an issue and is pulling the other down.
could be clogged filters in the VST,injectors, or engine.
each of those engines has about 12 filters under the hood.
could be an o2 sensor.
could be a lift pump leaking.
could be a bunch of things.
only way to tell is by monitoring fuel pressues and spark Kv at the failure RPM and load.
So I went down to boat today to see if i could fix the problem. First I pulled the plugs and although they weren't fouled there was some carbon buildup on them after only about 15hours. Any way cleaned them up and reinstalled. Next I opened up the vst tank to find the filter with some brown residue on it. Cleaned it up reinstalled everything and took the boat for a ride. Boat ran great in fact it seems the other engine wasn't keeping up. I'll have to do the same to it. The carbon is a bit of concern after such little use so I will monitor. Thanks for all the replies.
It may not be fuel related at all, I have a 90 and a 115, both two strokes and they both gradually lose rpm especially when running in chop. A previous 70 did the same, I'm wondering if there is a friction device that can be adjusted to help with this?
Haven't had a chance to study on it yet as it is fine above 3200 or so.
