2009 90hp starting issues
  • 2009 90hp starting issues
    So here goes again
    my brother was having issues with his 90hp starting ,
    I am 2000km away so i can only give him over the phone advice ,
    last year he was having issues starting ,most cases he would have to hold the fast idle to get it running , this tellms me its a fuel problem , once it runs and warms up he says no issues but sometimes idles up and down , well needles to say the bastard caught on fire and pretty much melted every wire on it while lobster fishing , he has since brought it to a yammie guy who had a pile of parts and he apparently changed everything but the ecm, he suspected the voltage reg was gone and it over charged .kind of made sense for a bit as overcharging would cause sensors to act up or even injectors i guess, well he spent 1800 bux to have repaired ,installed it today only to find he still has to hold the fast idle to get it running , does any of this make sense ?
    Model?
    And yeah, assuming the idle issue is fuel related, it makes sense he's still got the same issue bc he never resolved it prior to the fire.
    Jason
      isn't this is the type of post where Rodbolt would give his
      "insert the knife between the second and third rib. " advice?
      could be an F90 - or 2009 was also the last year for the carbed 2-smoke 90
        he mentions injectors so it must be a F90
        also km so not likely the motor is one from around the USA
          right.
          When I got the seventh line of the first sentence,
          my mind ran off the rails...
            holding the fast idle could mean he has to open the throttle some to allow more air in.
            if so, that would mean too rich on fuel at idle .
            could the IAC not me working?
            or too much fuel pressure,
            over filling of the VST and dumping fuel into the intake ?
              It is oh so difficult to put an F before the two, maybe three, numbers and two, maybe three, letters after those two, maybe three, numbers.
              I am starting to rethink trying to help wannabee backyardigans. If they are incapable of stating a model identity are they capable of removing the top cowling?
              Hell, they might even need help getting a motor to a dealer.
              What say yee?
                Need more coffee
                  Guys sorry f90
                    Originally posted by arctic 1 View Post
                    Guys sorry f90
                    Getting there. What is the rest of the information?
                      Guys sorry f90
                      Mr Arctic
                      All the information on the data plate attached to the transom bracket is what the the fine, but somewhat sarcastic, gentleman are looking for. They will help you then.
                      Where are you located if I may ask?
                        Mr Arctic
                        Not trying to be sarcastic. Trying to make a point. Thought we would have had it the first go round.
                        Remember getting the mules attention?
                          Hey guys sorry was on vacation, the engine wasnt in front of me at time of post , actually 1000miles away , i can take a little sarcasm lol, i havent followed up with my brother but i beleive he sa it fixed. Located in canada arctic ,Iqaluit ,nu basically no resources here ,you guys have saved me plenty of times over the years . Much appreciated
                            What was the fix?
                              Townsend i am pretty sure it was the iac
