Mercruiser trim motor control - Boscoe? anyone?
  • Mercruiser trim motor control - Boscoe? anyone?
    I happened across this information today - and am trying to puzzle it out.
    It appears (at least some) Mercruiser drives use a single relay to operate the trim motor
    and the trim motor has a ground
    as well as the familiar blue (presumably up) and green (presumably down)
    to provide the +
    what surprises me is that the green power is provided directly through the control switch -
    no relay involved.
    Any thoughts on that?
    (its also interesting that the control switch has three buttons -
    two for 'up' - apparently one in series with a limit switch)
    looks to me that the button switches are heavy duty so a relay is not needed to carry the current.
    the in and out does confuse me
      You have a trim up and a trailer button, that trims the drive all the way up.
        must be;
        except not the 'trim limit' switch -
        so they run the blue through a relay.
        I suppose,
        since there is no powerhead being moved around,
        just the drive housing -
        the amp draw of the trim motor may be a fraction of that of an outboard
          That's a really old system there. I'm going to guess something like mid-80's and earlier. Since about then, there are two solenoids being used - one up and one down solenoid. I wonder why the change, though - was it because that old system was flawed... or is the newer system actually less expensive to produce? I dunno.
