Originally posted by arctic 1
View Post
2016 250 vmax fuel issues
Boscoe ,i just want to say thanks,you the man!!!! It was exactly as you said. On the side of the vst tank there is a check valve. When i had the tank off before i cleaned it and was pretty sure i cleaned that little screen and the check valve. When i took apart today there was a small piece of dirt on the ball bearing in the check valve not allowing it to close. Put it in the water tonight and its running like a dream . Future reference the amazon pump would have worked just fine . Cant thank you guys enough
