Thanks.
I have not checked for, or touched any screws related to linkage adjustments. Not familiar with them, and nobody has been in this motor but me. However, early on while on the water, i couldn't get the boat into neutral while approaching the dock. I panicked a little and forced it into neutral to avoid hitting the dock -- could that have tweaked some linkage?
Leak down test? Nope -- never done anything like that, but I will get with my auto-mechanic buddy and see if he can help me do this -- I believe you laid down the procedure above. I'll review you post above and try to get the numbers back to this blog. It will be a couple weeks though as i'm going out of town.
What do most sensors have in common?.... I believe you're leading me to either the ECM or the wiring harness. My thoughts:
- The ECM seems to be functioning well based on the fact that the active monitoring is demonstrating performance with the YDS.
- The wiring harness? ...Maybe there is a bum sensor a broken/corroded ground wire that is messing with reference voltages, as you said earlier. Or maybe.
Another thought -- maybe dirt in the throttle body affecting the map reading?
