I have a 2002 F115 and it has this problem that is driving me nuts. The boat runs great until I run it for 30+/- minutes straight at cruse RPM (4500) and when I stop it will spit, surge, and then stall. It will also do this when it’s cold at idle sometimes. The boat hits WOT no problems. When it running like crap I can unplug the TPS and it will shoot up in RPM for a split second ( I can hear the IAC valve open up more) and then go back to idle and runs great. After I unplug the TPS and it goes back to idle I will plug it back in (no change) and I can run the boat all day long with no problems but as soon as I shut it off and then restart it, it runs like crap again. This is what I have done in the last week to try to fix this.
I put a reman set of injectors in (no difference)
It was plugged in to the yds and no codes. Also when it was running bad and But couldn’t see anything because the numbers were all over the place. When running ok everything seemed to be in check.
VST tank was cleaned last summer with the filter change (I didn’t have to do it but I did it).
Fuel pressure is at 37-38 running and at 44-45 with just the key on
Brand new Iac valve installed
Brand new T-stat installed
Tried a computer from another motor but didn’t work
I did a compression check and all cylinders with in 2-4psi
I changed the water sep (old filter didn’t have any water or dirt in it)
The boat has a full tank of new gas (high test)
Cleaned the little filter on the motor ( not dirty)
I’m thinking it could be a Intake Pressure sensor, or an Crank position sensor.
Can bad spark plugs do this? I don’t think so because I can make it run great by unplugging the TPS and the same goes for a valve getting hung up? If a valve was hung up it would never run good.
Thanks for any possible help.
