I've got a good running 1986 115hp that drains oil thru the carbs when the motor is tilted up. Oil comes from the intake of #2 and 4. Have removed oil pump and inspected and it appears to be the check valves are leaking when the oil tank is high enough over the carb ports to drain. Will drain the entire oil tank if left tilted long enough. Suspect I need to replace pump but don't want to if that's not the problem.
Any other ideas? Have a couple weeks before next club tournament.
