Motor has run fine on a few trips, but stalled twice when hot and >15 minutes of idling/low-speed (<1200 rpm where LP pump runs intermittently -- 10sec on, 20sec off).
After it stalled, drained the VST the next day and only got 4-5oz out. Yes I used the Schrader valve when draining. Makes me think it's a fuel issue on the low pressure (LP) side. Either VST vent to atmosphere is plugged, LP pump relief valve open, or LP failed.
I can barely blow through breather (check-valve) in VST vent to atmosphere. Suspect this is normal? Cannot blow through in reverse direction.
Relief valve leaks a little (can blow in both directions, but very restricted). Can't fully open it by blowing, but can easily move ball off-set with screwdriver. Spring & ball appear intact.
After re-installing, priming, and idling for a couple minutes...I drained the VST and got >12oz out. Seems the LP system is capable of filling VST at idle, just not when motor is hot??
Also discovered white residue on both fittings of the pressure relief valve. When scraped off, very fine powder. Only visible on fittings & inside of line where fitting was in contact.
I suspect this calls for replacing the F filter (inlet of VST), and cleaning screen inside VST tank. Can this be done spraying carb cleaner thru drain? Or Intake manifold and VST has to come off?
