Here is what she is doing. after start up and warm up.
The idle will fall off till it dies.
I had it in to a shop, They said the injectors needed cleaning and that was the problem.
But this weekend out chasing tuna. It was doing the same thing.
Pull the throttol lever back to in gear idle and it would idle along then would idle up a grand then start
dropping off till it died..
Now if I shut it off then restarted it would idle fine. Right at 8 grand .
but after running at like 14 to 18 hundred and pulling it back to in gear idle it starts this again..
what ever was needed to run at 6 to 8 mph.
All the filters are clean and good gas, new plugs. The engine runs good
execpt for the dieing thing.. after they did the injectors cleaning. my mileage is up. and
throttle response is good. Engine is a 2005 model with 570 hrs on it.. always serviced
