Pretty sure I slipped a prop this weekend. was running at about 5200 RPM on a 2002 200HPDI, felt a sudden deceleration accompanied with increase in RPM. the boat would only move at idle speed despite the RPMs the gear would slip above 2900 RPM. Pulled prop and found a small amount of water on the prop shaft. the area behind the thrust washer was dry and packed with grease. The void area behind the prop outside of the thrust washer was filled with water. Is that normal? trying to figure if I have something more serious than just a slipped hub.
Thanks!
Thanks!
