If your not worried about it working, I'd flush with fresh water from both ends, (LU off) let dry or blow dry, then as posted, seal each end with 5200, epoxy, etc.
blocked pitot tube -- cutaway diagram of F40 lower unit??
My thoughts were directly to the LU, (which would have to be removed), NOT going thru any hoses. High pressure anything would likely blow the hose off.
but then being filled up with grease would be better than filled with saltwater
to the OP.
we all have seen a lot of old motors that the pitot were never used or flushed, but never did the lower unit metal get ate up with corrosion. there is a good chance there was something more going on to do something that badLast edited by 99yam40; 06-09-2019, 09:22 PM.
I understand, but still that drilled hole coming down into the LU where it meets the pitot would get filled with grease and be hard to get it back out.
to the OP.
we all have sen a lot of old motors that the pitot were never used or flushed, but never did the lower unit metal get ate up with corrosion. there is a good chance there was something more going on to do something that bad
I oft wonder how aluminium can last as long as it does in salt water.
The way the alloy split then calved off on my old Yammie suggested to me that the corrosion was inside a void or gallery in the lower leg and was causing expansion, then cracking, then more corrosion. It was ugly, but not as horrifying as sucking out a mouthful of "West Texas crude" after inserting the drill bit progressively and then sucking out the debris (by mouth) from the pitot tube each stroke!
So maybe there was something else going on down there as boscoe99 says?
I should have cut the old leg open with a grinder to do a post-mortem before taking it to metal recycling.
I have to say that, other than that issue, I have never had a problem with Yammies. The fact I purchased another is proof of my trust in them, but given the low price of modern GPS combos, their popularity, and the accurate speed over ground they give, I cannot see the need for a pitot tube nowadays on tiller steer models.
If you are running into a current, the pitot-tube speed will be an overestimate of speed over ground. This would lead to errors in planning trip duration and trip fuel consumption if those plans were based only on pitot-tube speed. GPS-sonar combos give you speed over ground, course over ground, distance travelled, and time/distance to destination without any link to the motor.
the flaw in you thoughts is the motor is pushing thru that current that is flowing against it, so the fuel used would be more than that using the GPS distance and the speed thru the water would be more than the GPS speed.
I think that was said correctly
There is speed through the water and there is speed through space (over ground). Completely different. Just depends upon what people want.
The highest tech most advanced airplane in the world, with maybe three GPS and other navigation systems installed, is always gonna use a pitot tube derived speed for landing and take off.
I bought a used marine Hummingbird GPS "just removed from a boat" excellent condition a couple years ago from E-Bay.
While changing the settings to match my exact, older unit(screen failing), I found the TOP RECORDED speed well over 175MPH!!!
Most of the "tracks" (not erased) was between Miami and the south Keys.
I suspect it came off a sea plane....
I am dealing with this on the lower leg of my '88 Yamaha 90 but I think the real issue is that salt water is getting between the pitot tube with is stainless and the alloy casing. I am also experiencing "calving off" as the corrosion increases and forces a section of the aluminum off. At the heart of it you can see the white corrosive line going up the leg just above the pitot tube entrance.
ÂÂÂÂÂ
