Just bought the boat 06 Sea Hunt 22bx. Test run the motor on muffs in the driveway. Got 20 fett from the ramp and it cutoff. Pumped the bulb..nothing happened.got it back home. Changed the Fuel water separator cartridge, the fuel filter in the bowl, tried to start on time. Changed the filter on the top of the LP pump, direct wired pump it operates and pumps HP pump comes on at ignitiion on for 10 sec. I drained the VST and got about a 1/4 pint of water.opened it up and there was a thimble of sludge but filter was clean. Did not have a psi gauge but when i diconnected the gas line there was very little residula pressure. Plugs are new and they were dry and they fire. I am thinking a new HP pump. The Tach did not work but i believe it is bad as the person i bought the boat from had just about everything under the concsole wired wrong. What am I missing....any help would be appreciated.
New to me 2006 Yamaha F200TXR cutoff 29 foot from dock
so this disaster just happened recently?Originally posted by Afterhours12 View PostI am thinking a new HP pump.
Certainly sitting in water will kill the pump -
not good for the working of the fuel injectors, either
You can easily check the functioning of the pump,
there is a Schrader valve on the fuel rail to attach a gauge.
At key on, the pump should run for a few seconds, and build pressure to ~44 psi.
Are you sure you have all the water out?
If the pump does run, it should result in some 'circulation'
I would drain the VST several times, to make sure.
I would be very concerned about where the water came from.
there is a very good chance that there is a lot more water in the tank.
all that is needed is get the boat/tank at the proper angle or slosh the water around by moving the boat around and the water is picked up again.
may need to drain and clean the tank of all water before adding all fresh gas.
any water in e fuel will kill the fuel and needs to be dumped
fuel flows thru the pump motor to lube and cool it,
run water thru it and that is not good.
