Motor will idle pretty well, I can tell the udle is just a wee bit off, but most wouldn't notice it.
If you ever so slightly give it throttle, it will bog bad, or just stall.
You can chop the throttle hard and it will rev up. Sometimes if you ease it bit by bit it will fight through the bog and rev up.
Previously diag fuel pressure reg was bad, replaced that, along with going through all the filters, vst, etc. And ran off a portable tank.
Doing same thing. No codes, the parameters look good. Not sure what's going on.
What would be a cause of this? I think it's fuel related, but it seems to check out...maybe a bad or clogged injector?
