Hi there,
Back again asking for your advice, as again having conflicting info!
Motor F70 2011/2012 : only 2 hours then was sitting in a yard until i purchased couple of months ago.
Have basically overhauled engine and been out today for the first time, however, conflicting opinions about the breaking in period and what i should or should not be doing.
For info:
- all fuel was drained, cleaned tanks, all filters replaced and filled up with new fuel
- oil drained and filter changed
- cam belt and thermostat changed
- water pump, gear oil changed
- anodes changed
Was told to keep between 2500-3000 for the next 10 hours and then push to over 3500-4000 get boat on plane
Reading the yamaha manual, it suggests differently.. I am not sure what the first 2h were..
I will be doing check up and oil change at 20h as per the maintenance schedule..
Any advice on the experts about breaking in an older engine?
Merci!
For info:
- anodes changed
Merci!
