2004 f115txrc
Running issue. Give it throttle and it tops out at 3,000-4000rpm (varies) and can't get on plane.
On trailer it idles fine, but soon as you give it the slightest throttle it bogs or dies.
Check fuel pressure and it's fine at key on and idle is good at 36. WOT spec is 44.
When I give it throttle, even very slowly...from about 700 then to 900-1000, it will bog and the fuel goes to 44-48ish. Sometimes it goes to 50+ and dies.
It is normal for pressure regulators to spike like that, especially when throttling up so slowly?
Compression is good, did drop test on cylinders (injector and spark) and good there.
