Originally posted by TownsendsFJR1300
View Post
Originally posted by 99yam40
View Post
The prime start is working like it should. The device works like a timed plunger or solenoid. When power is dropped, when the engine is shut off, the carbs slowly becomes choked as the prime start cools down. When you start the choked engine, the prime start slowly releases the choke and within a minute or so the choke butter flies are wide open. Turn the engine off and the prime start slowly chokes the carbs again. The temperature of the engine has no affect, although once the prime start warms up, the cycle is a little faster. Kind of a wacky setup, but my spark plugs are now burning clean after checking them following numerous cycles. You would think the unnecessary choking of an already warm engine would fowl them, but it is not the case.
Now an answer to my question in my previous post.. If you notice, the spring that keeps the choke open is in the wrong position! Three carbs were like this. In the picture, the little loop of that spring is at about 5 o'clock. As I mentioned quite a few post back, the choke linkage was "flapping in the breeze" when it should have been under spring tension in the open position. Initially when I hooked everything up, the prime start held the choke closed firmly. I could not move the linkage. Once the engine began running and the prime start released the choke linkage, I noticed the linkage was loose again and gravity held the linkage down keeping the carbs choked.. I looked at my new set of carbs that I purchased, which are still assembled, and I saw the problem. On that set of carbs the small shaft springs were holding the chokes wide open. I corrected the springs on three carbs, turning that little loop counter clockwise and hooked it to the 7 o' clock position and now, all is good.
