No power to motor
  • No power to motor
    2001 ox66 150hp. I'm having issue with this motor . All the suddenly I can't get any power to the motor to start it up. 1st I though I was the battery .so I replace both .clean all the connection . Still no power all I hear it click click from the starter relay . Replace with brand new one .still no power . Every time I turn the ignition to on my tach with flicker on and off . When I try to start the motor all the tach goes out . Power tilt and trim won't work either . Trying to trouble shoot this problem . Please any forum member can give me idea what I can check next .
    Thank
    Ground or ground cable
      Jb123 I have also try hooking the battery straight to the motor with jumper cable to bypass all other wire .Still no luck getting power to the motor.
      Thank
        the tach and control box trim and the start circuit all take power from the keyswitch.
        the tach ground is from the keyswitch.
        will the trim on the pan work?
          Besides the above, do you have a "Perko type" MAIN on/off switch installed?
          Its NOT common for the contacts inside to get crappy or the wires to loosen up/ corrode inside the switch.
            Rodbolt the trim switch on the pan also doesn't work all I get is a click click when I trim it up or down. I also have a perko battery switch . I clean the connector make sure every secure down. I even replace it with a brand new one. Still get get click click when I try to start the motor or trim from the motor pan or from thorttle. If I jump start the starter it will spin.
              you most likely have a bad cable.
              do a forum search on voltage drop test and find which one failed.
                take a look to the fuses, you have two together in the starter side of the engine
                  Thanks rodbolt turn out to be a bad cable.
