Hi Guys I have a 60hp high thrudt motor, I wish to add a yamaha pro series water pressure gauge , can I remove the clear pipe which is connected to the back of the speed fuel gauge to the new gauge, if not please advise thanks Dave
Water pressure Gauge
I suspect that what you have is a T60***. Always provide the complete model number to anyone when asking for information and/or parts for the motor. Otherwise, you might buy something that won't fit.
Gauges and block fitting/tube are in here:
2014 Yamaha MRP Catalog
Attach point is here:
There are SEVEN MODELS for that engine(year, HP, 4 stroke):Originally posted by 99yam40 View PostI am sure this is not what is printed on your motors tag for your model #
2006 and Later Yamaha Outboard Parts
The specific model #, at least in the future is needed..Scott
Absolutely. Why do you suspect the usage of this gauge with you motor?Originally posted by Dave Blaber View PostMany thanks Boscoe99, and others for your input, it's a T60hp 2007 4stroke, will I be able to use a pro series II water pressure gauge?.
My comment pertained to your first post only asking about adding a water pressure gauge. You then came back and made a comment about wanting to replace all of the gauges.
It is all doable. I just did not understand why you did not bring up the complete scope of work (changing all of the gauges) in your first post instead of merely asking about a water pressure gauge.
No worries mate, my initial scope of works was only the water pressure gauges, but have decided to remove all the digital gauges to pro series II gauges. I am hoping the tacho change over will be a simple plug out and in, I will probably be needing your advice when I connect the volt gauge and water pressure gauge, I should be ok with the fuel gauge , thanks
