I have just replaced trim motor on 2001 tlrz 70 hp. I have tightened the mounting bolts but am stii getting fluid leaking from around the base of new trim motor. Btw new trim motor is an after-market. Any ideas? Are the bolts supposed to be torqued to a specific value?
Trim motor question
It seals with an o-ring, right? I'm sure there's a torque value, but it won't be anything special since it's an o-ring. Check your service manual, though, if you want. Tightening evenly is probably more important than the exact torque value. When you put the new motor in, maybe you misaligned the o-ring? Unless the mating surface(s) around the o-ring are corroded? How did it look?2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Yes, it seals with o ring. Don't have service manual. Was very patient and kept tightening slowly. That is one thing I was wondering about. O-ring just slips onto base of motor, not really big enough to slide off on its own. No corrosion to speak of. sysem was pretty clean and had plenty of fluid. Maybe not tight enough, didn't want to strip or snap a bolt off.
They're pretty small bolts so it really wouldn't take much. You should pretty much be able to tell by feel when it's snug enough.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Did you replace the sealing o-ring? If not, it should be...
The parts diagram shows one seal (PART #28): https://www.boats.net/catalog/yamaha...trim-tilt-assy
Rubber hardens up, flattens over time allowing leaks / failure
As for tightness, good and snug should be plenty...Last edited by TownsendsFJR1300; 05-17-2019, 07:31 AM.Scott
These are the torque specs from a 1999 70hp service manual:
https://imgur.com/a/XgTSrSA
With o-rings and rubber gaskets, you can't go too tight.2011 F50TLR, 2010 G3 V167C
Bolt torque is a non-issue in this situation.
Once the two metal mating surfaces -
the motor and the t/t casing -
are flat against each other,
tightening the little bolts more can do nothing - other than snap them.
Are you sure its a "leak" and not just a bit of residual fluid oozing out?
I was thinking that perhaps the mating surface on the counterfeit trim motor may have a flaw. Maybe where a seam from the manufacture molds come together??? The quality control may not be as diligent.
As fairdeal said, 'residual fluid' seeping from the seam is great possibility too.
I would guestimate the torque being somewhere in the 50 to 80 inch pounds.
I had to look, and while I don't have FSM handy, I found this https://www.engineersedge.com/torque_table_sae.htm
Using 1/4"- 20, in aluminum it shows 45.6 inch lbs.... So 50 inch lbs or 4 ft lbs.
Over torque will cause the plastic motor housing to crack at the mounting holes in a few years.
I'd recommend TefGel on the threads for future fastener removal too.If its got teats or tires, you bound to have trouble with it....
I see rejestered had better info.... 'Gear pump Mounting' ? Is that it? So 3 or 4 Ft lbs depending on model, not very much....
Inspect the sealing surfaces where the o-ring is supposed to do its job, and use only a new o-ring (can lubricate it in the hydraulic fluid)
Give it a cleaning with aerosol brake cleaner or electrical contact cleaner (even mild soapy water and low pressure rinse) and watch to see exactly where the seep is coming from. Maybe the new motor leaks?If its got teats or tires, you bound to have trouble with it....
Originally posted by rejesterd View Post
Not if you read what I was saying correctly.
"I can't get enough hugs from my kids" = The more hugs the better.
"You can't go too tight" = The tighter the better.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Thanks to all of you. Appreciate the info. Found the problem, the after market trim motor came with an o-ring of considerably smaller diameter of cross section, i. e thinner than original. Believe that was the problem. Had the bolts sufficiently tight. Problem has been resolved.Thanks again to all for helpful input.
Regards, Bones
Originally posted by bones1966 View PostThanks to all of you. Appreciate the info. Found the problem, the after market trim motor came with an o-ring of considerably smaller diameter of cross section, i. e thinner than original. Believe that was the problem. Had the bolts sufficiently tight. Problem has been resolved.Thanks again to all for helpful input.
Regards, Bones
Great to hear you git R done. Thank you for returning and giving a report and closure.
Now, next time, we can pass on your information and suggest they size up the included o-ring.
Don't be a stranger...
Cheers!If its got teats or tires, you bound to have trouble with it....
ÂÂ
